- Apr 15, 2015
On Friday may 29, 10130 installed and everything seemed ok until I put the system to sleep. When I woke it up I had no image on my monitor and it said no signal. So, I had to manually reboot, which worked.
The start menu was changed slightly, I had nothing but the power button, settings and file explorer had vanished. I found out how to get them back on the start menu and everything seemed ok until I put it to sleep again. When I woke it up it again had no video image, so again I had to reboot and again, everything came back on but this time none of the icons on the task back functioned. No start menu, no cortana, no notifications, etc.
So at this point I rolled it back to the previous build but again none of the task bar icon responded.
So, while I sit here at work, I'm downloading the latest ISO and will reinstall windows when I get home.
And so goes saga of testing new software, lol.
windows 10 (latest build)
Asus P9X79 MB
i7 3930k @3.2 (haven't needed to oc)
GTX 690 (Still screamiln)
32 GB ddr3 ram @ 1333
Logitec usb mouse, keyboard and G930 headphones
Asus P9X79 MB
