Have not been able to get automatic IP on LAN because DHCP won't start .
The error message when trying to restart DHCP is :
"Windows was unable to restart DHCP Client service . Error 5 : Access Denied."
I am able to connect to the internet with a static IP .
I have no restoration points on my computer .
My specs :
OS : Windows 10 Pro 64-bit version 1511
CPU : AMD FX-6100
RAM : DDR3 12 Gigabytes
Motherboard : Gigabyte GA-990FXA-UD5 (Socket M2)
Graphics : AMD Radeon HD 6700
Ethernet : Realtek PCIe GBE Family
This is what I have tried so far -->
The usual commands :
I have , of course , contacted my ISP and they have found nothing wrong on their side (or in the router) .
I have also uninstalled / reinstalled my network adaptor .
Have also tried modifying the registry by assigning permissions at :
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\DHCP\
Now digging deeper , I set the command :
CMD /K SC QC DHCP
This was what I got (note the system is in Spanish) :
TIPO_INICIO : 2 AUTO_START
CONTROL_ERROR : 1 NORMAL
NOMBRE_RUTA_BINARIO : C:\Windows\system32\svchlst.exe -k LocalServiceNetworkRestricted
GRUPO_ORDEN_CARGA : TDI
ETIQUETA : 0
NOMBRE_MOSTRAR : Cliente DHCP
DEPENDENCIAS : MSI
TDX
AFD
NOMBRE_INICIO_SERVICIO : NT Authority\LocalService
Any ideas? ,
Thanks .
My specs :
CPU : AMD FX-6100
- ipconfig /flushdns
- netsh int ip reset c:\resetlog.txt
- netsh winsock reset catalog
- netsh int tcp set heuristics disabled
- netsh int tcp set global autotuninglevel=disabled
- netsh int tcp set global rss=enabled
- ipconfig / release
- ipconfig /renew
CMD /K SC QC DHCP
ETIQUETA : 0
DEPENDENCIAS : MSI
TDX
AFD
Any ideas? ,
Thanks .
