Have you tried, Right Click on empty space of your Desktop and click on Display Settings, then click on Advanced Settings. You should be able to change your resolution there. Also the drive might not show up until you put a disk in. Check if it is listed in the hardware manager.Charles
Similar problem, upgraded yesterday and the DVD drive has disappeared. I tried the above fix but this did not make it visible. Also lost the driver for my screen so am having to work in a very unusual resolution but cannot load the drivers as the DVD will not work.
above is the sys info. Any ideas gratefully received.
thanks
When DVD Drive is Missing after an upgrade try this
Resolution 5: Create a registry subkey
Note To use this method, you must be logged on to Windows as an administrator. If you need help verifying that you are an administrator, go to http://support.microsoft.com/gp/admin
Important Follow the steps in this section carefully. Serious problems might occur if you modify the registry incorrectly. Before you modify it, back up the registry for restoration in case problems occur.
To create the registry subkey, follow these steps:
1. Press the Windows logo key + R to open the Run box.
2. Type regedit in the Run box, then press Enter. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow
3. In the navigation pane, locate the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\atapi
4. Right-click atapi, point to New, then click Key.
5. Type Controller0, and then press Enter.
6. Right-click Controller0, point to New, and then click DWORD(32-bit) Value .
7. Type EnumDevice1, and then press Enter.
8. Right-click EnumDevice1, click Modify....
9. Type 1 in the Value data box, and then click OK.
10.Exit Registry Editor.
Restart the computer.
