Hard drive stuck in hibernation mode.
SOLVED Discussion in 'General Discussion' started by jaisonwhitekar, Oct 22, 2018.
  1. jaisonwhitekar
    jaisonwhitekar
    Oct 22, 2018
    28
    Hey guys, long story short I decided I was going to switch from Windows 10 to Kubuntu permanently. In doing so, I wipe my main OS partition and left my secondary storage HDD intact for later use in Kubuntu. Little did I know I was using hibernation to HDD in windows and now this drive won't boot unless I got back into windows and disable hibernation mode.
    This is where I realize my **** up. I completely wiped clean my original OS so now I don't have a way to access the drive. Is there any way to fix this? Can I use a secondary windows pc and disable it from there? I read somewhere that going in and messing with data on the drive is a good way to loose all the data since apparently the information on it is somewhat encrypted due to data shuffling (for hibernation).
    #1
    1. Advertisements
  2. jaisonwhitekar
    Ben Myers
    Nov 6, 2017
    171
    25
    If you using Windows now and have a USB stick or can burn a DVD, go to
    https://www.microsoft.com/en-us/software-download/windows10 and download and run the Media Creation tool. It will create a bootable device that you can use to start the problem computer and reinstall Windows 10. Also, with most versions of Linux, I don't think you have to remove the existing operating system.
    Ben
    Ben Myers, Oct 22, 2018
    #2
    1. Advertisements
  3. jaisonwhitekar
    davehc
    3,889
    746
    Denmark
    Are you able to get into a command prompt at the opening of the PC?
    If so, type powercfg.exe /hibernate off
    Never tried it from the boot command prompt, but it might work
    davehc, Oct 22, 2018
    #3
  4. jaisonwhitekar
    Wolfie
    2,384
    267
    Hi jaisonwhitekar,
    it sounds like you put the GRUB boot manager on the wrong drive (possibly your back-up HDD?), in Linux, it would be dev/sda1. If you placed it on dev/sda2 as an example, it may not boot, are you getting any messages concerning the bootloader or not?, have you tried "Boot Repair"?:
    https://sourceforge.net/p/boot-repair/home/Home/ :):):)
    Wolfie, Oct 22, 2018
    #4
  5. jaisonwhitekar
    jaisonwhitekar
    Oct 22, 2018
    28
    thankyou!! well that was usefull!!
    #5
    Wolfie likes this.
  6. jaisonwhitekar
    Wolfie
    2,384
    267
    Edit to my previous post.
    GRUB should install on dev/sda and not dev/sda1 as I posted above, sorry. :):):)
    Wolfie, Oct 24, 2018
    #6
    jaisonwhitekar likes this.
  7. jaisonwhitekar
    jaisonwhitekar
    Oct 22, 2018
    28
    thanz wolfie!
    jaisonwhitekar, Oct 24, 2018
    #7
    1. Advertisements
You'll need to choose a username for the site, which only take a couple of moments (here). After that, you can post your question and our members will help you out.
