- Jul 4, 2015
Anybody have any idea on this?
I installed the Korean language pk on the W10 Home upgrade for a Korean person, it went OK, got it working and got the language tool bar on the tray, it has ENG as the "primary" language set, and the KO under as the 2nd choice, I have it that way on my W10 Pro machine, as I did on 7 and 8 and 8.1. On each of those I can select which language to use, but on this one even though the language bar is the same, the system now has pretty much everything in Korean, all the start menu stuff, all the explorer stuff, pretty much everything, mine is ALL English even with the Korean language pk is installed ,only thing I use it for is if I want to mess with typing in Korean. Which I don't do much.
So now I'm stuck and can't seem to find any setting at all that makes English the main language. I checked all settings again, and English is the TOP (1st) one on the list.. kind of has me stumped ,only thing is maybe cause mine were all Pro versions and this is the Home version, I dono, I doubt it.
I'd end up having to uninstall the whole language pk to get it back to English I guess If I ever had to repair the thing again.
