Hi. I have been using VMPlayer which runs as a guest Linux OS on Windows 10 for quite a while. I applied some Windows updates a couple of days ago which included the new Creator version. Yesterday when I started my VMPlayer VM machine I received the error as noted above as subject. Somehow I think the Ethernet adapter settings were changed. I searched the web and found some hits on this which included step by step instructions on how to install the service - VMware Bridge Protocol under Settings, Network & Internet, Ethernet. The steps are straightforward and I'm sure I didn't make a mistake. I then stopped and restarted the VMware NAT and DHCP services. I then rebooted my laptop. I received the same error when I started my VMPlayer VM machine.
I'm hoping some Windows users may have seen this issue and may provide me with some advice.. stuck now and not sure how to proceed with this issue.
my env.
EDITION - WINDOWS 10 PRO
VERSION - 1703
BUILD - 15063.403
VMPlayer - version 6.0.7 (I do not have Workstation installed)
my env.
VERSION - 1703
BUILD - 15063.403
