win10 not recognize my Pin.
I put the pin but I receive "your pin needs configuration. I said Yes, and he repeats again and again without end.
can some body help me?
many thanks
birdo
Click "Sign In Options"
Choose the normal text password option
Login with you Microsoft Account password
Then go to
Settings -> Accounts -> Sign-in Options
And select "Windows Hello PIN and either use the Change or Remove buttons.
ThAnks
I have no option to use password. The system only ask for PIN.
and when I put it (I did not forget the pin) he says the pin needs configuration....and repeat ...repeat...never end...
Birdo
