Power Managment Custom Plan Resets to default Settings.
I must Say Windows 10 is Good, Fast and Reliable.???.
But there are Still Some Things that M/S Just Can't Fix or just could not be bothered Fixing.
Like Your Custom Power Plan that one Designs, that Keeps Loosing it's Settings and Reverts to Default.
It is Totally Unreliable, You just get all the settings the way you want and some time later in the day you check it and find it has reset to Default Settings.
The same problem has been there as far back as I can remember with 8, 8.1 and 7.
Ad
Advertisements
