- May 4, 2015
I am not able to install my Realtek USB Network Adapter. Anyone run into this or have a suggestion of how i can resolve this.
According to Realtek they will work on both Windows 8 and Windows 8.1 so they should be satisfactory for Windows 10, at least for the time being.Driver Install - Manual Method
- Download the driver and extract it to a folder.
- Open the Device Manager.
- Right click the device you wish to change the drivers for. You can select Properties > Driver > Driver Details to check you have the right device.
- Choose Update Driver Software.
- Select Browse My Computer For Driver Software.
- Select Let me pick from a list of device drivers on my computer.
- Select Have disk...
- Select Browse..
- Navigate to the extracted folder and double click on the .inf file
- Hit OK, then Next and the driver(s) will then begin to install.
I do not understand what that means.keeps kicking it back to cd drive
