I have an Asus Z87 Plus motherboard with the latest bios.
When I try to schedule an RTC time in its bios the entries drop out as each successive entry is made (day, hour,min) and therefore there is nothing that can be saved. Disabling of the bios "fast boot" works for some people, but mine is disabled, anyhow. and my problem is different because it can't be set up in the first place.
Didn't use it before the Win 7 upgrade, so I don't know if it worked then.
One only reply in the Asus forum suggests it is a problem with Win 10.
Has anyone come across the problem or know of a possible fix?
Thanks for any help.
