Runtime Broker issues: massive network downloads and 100MB RAM usage
I installed Win 10 Home (upgrade from Win 8.1) on two PC's on July 31. One a desktop PC, the other a laptop. Both systems were working great until yesterday (Aug 6) when both machines started doing major network downloads (the desktop showed 100 GB of download overnight). Using task manager it was easy to see that the culprit for the downloads was the 'Runtime Broker'. I also noticed that the Runtime Broker also starts sucking up RAM memory (100's of MB). I can stop this process and the network downloads stop, but after 10 or 15 minutes, Runtime Broker reappears and starts network activity again.
This was not an issue before yesterday. Did Microsoft force a Win 10 upgrade?
My questions are:
1) anyone else experiencing this issue, and
2) if so, do you know of a fix?
Thank you,
Barton
I just learned how to locate the upgrade activity - the machines were upgraded on August 5 with
"Cumulative Update for Windows 10 for x64-based Systems (KB3081424)"
RuntimeBroker (now Shell Infrastructure Host) high RAM usage 0
SOLVED Event id 10016 Runtime Broker 4
Windows 10 Runtime Problem 0
SOLVED Runtime Broker Killing my computer 3
Runtime Error 1
Runtime Error 1
Runtime error LogonUI 1
Runtime Broker 2
