Automatic repair issue
My computer is stuck on automatic repair after I reinstalled one of my drivers. How can I fix this through command prompt? Nothing else works and I can't save anything. What are the command lines for drivers and should I just uninstall them? I type in devmgmt or devmgmt.msc and nothing ever works. What do I do? Please I'm desperate. I'm not even completely sure what to do.
Please describe the error or problem that occurs when you run System Restore.
Ben
have you tried sfc /scannow followed by this, DISM.exe /Online /Cleanup-image /Restorehealth , from either Command Prompt or Powershell (right click run as administrator, either one will work). It will reset everything and may fix your problem...
You probably need to get into Safe Mode to change a driver. What driver was it that caused such problems?
