- Nov 19, 2013
Are you saying that, after installing this program that your start menu no longer functions properly, or....
The program does not show up on the start menu?
I've had no issue with the current build's start menu applet, however I'm running a pretty plain jane setup as far as installed applications.
Yes a previous and the current 10074. But not with loading programs, the menu will not load at all. The Windows Key will not load it either. Initially setup with 10074 the Start Menu was broken and then fixed again. The Start Menu was working until this non-boot issue which forced a Windows Reset to get into Windows. Once again, I'm not sure what caused the boot issue. But the reset should have fixed everything (including not breaking the Start Menu). Upon entering from what is supposed to be a refresh, there is nothing installed and the Start Menu fails to function.What's happening with your start menu? Wasn't it the previous build that had a problem whereby some programs wouldn't open from it?
I'm wondering if the reset may have put you pack to pre-Windows Updates. I'm thinking that this build had one immediate update and then a couple other subsequent updates that may address the issues you're experiencing.But the reset should have fixed everything
