SOLVED How to add "Scan with Windows Defender " and "Scan with Malwarebytes Anti-Malware " to right click ?
How can I add both these scans to the right click menu when I right click on a folder ( or zip file before opening ) ..... i've found plenty of links to add to right click on Desktop via regedit but not to actually to add as i describe above .... thanks
RE : Add Scan with WD
http://www.howtogeek.com/137083/how...ws-defender-to-the-context-menu-in-windows-8/
Note: it is applicable to Win 10.
RE : Malwarebytes
Open Malwarebytes > at the top, click Settings > make sure you are on General Settings tab > right side, put a dot at " Explorer context menu entry - Yes".
That's it.
RE : scan with windows defender.
There is a catch in this method published by howtogeek.
It will work on any folder but not on individual files. What I mean is, if you right click at a folder, you will see Scan with WD, but if you right click at a file, the option is not listed. Don't know why.
Thanks David ... MWB too easy ... d/l the WD zip .. Bingo ... job done ...
