Need Ultra-Wide Split Screen Monitor for Two HP Pavilions Desktops
To all that can give a simple answer and know-how to what I need to do.
I run two HP Pavilions desktops with a 19" monitor(s) connected to each PC. One old 20 years or so is about had it's last dance, and I don't think it is best to buy another monitor. So, I'm thinking of buying a 29" or 32" Ultra Wide Split-Screen monitor that will serve both computers. One PC has a NVIDIA GeForce 8400 graphic display card, the other PC has a AMD Radeon HD 6450 display graphic card if that is important for me to have if I buy the 29" or 32" wide screen monitor.
My first choice for a monitor is a this one listed below.
With this setup...I can connect the two PC's by HDMI cables to HDMI-1 and HDMI-2 inputs and work both PC's on the 29" monitor by Split Screen ( or PIP mode)
Am I able to do this?
Thanks for the replies.
29WK600-W
29" 21:9 IPS HDR WFHD Monitor
LG MONITORS
29" 21:9 WFHD (2560x1080) IPS Display
HDR10
sRGB 99%
AMD FreeSync™ Technology
3-Side Borderless Design
Tilt Adjustable Stand
PICTURE QUALITY
Screen Size 29"
Panel Type IPS
Color Gamut (CIE1931) sRGB 99% (Typ)
Color Depth(Number of Colors) 8bits( 6bit+FRC), 16.7M
Pixel Pitch(mm) 0.2628x0.2628
Response Time (GTG) 5ms (High)
Aspect Ratio 21:9
Resolution 2560x1080
Brightness 300(Typ), 240(min) cd/m2
Contrast Ratio 1000:1 (Typ)
Viewing Angle 178/178 (CR
≥10)
Surface Treatment Anti-Glare 3H
INPUT/OUTPUT
HDMI Yes (ver2.0, 2ea)
DisplayPort Yes
Headphone Out Yes
POWER
Type Adapter
Input 100~240V
Normal On (EPA Typ.) 20.5W
Normal On (factory out
condition Typ.)
32W
Power Save/Sleep Mode (Max) 0.5W
DC Off (Max) 0.3W
SPECIAL FEATURES
Picture Mode (Non HDR Contents) --> Custom,
HDR Effect, Reader,Photo,
Cinema, Color Weakness, FPS1
Game/FPS2 Game, RTS Game,
Custom (Game),
sRGB
Ratio Wide, Original, Cinema 1, Cinema
PIP PIP mode in Screen Split
DDC/CI Yes
HDCP HDCP2.2 / HDCP1.4
Key Lock Yes
Plug & Play Yes
Response Time Control Yes
Color Calibrated Yes
Adaptive Sync AMD FreeSync™
Game Mode Yes
DAS Mode Yes
Black Stabilizer Yes
Dynamic Action Sync Yes
Crosshair Yes
Flicker Safe Yes
Automatic Standby Yes
Six Axis Control Yes
Smart Energy Saving Yes
Reader Mode Yes
Dual controller Yes
Screen split2.0 (in OSC) Yes
4 screen split
My Display Preset (in OSC) Yes
On Screen Control (OSC) Yes
One Click Stand Set-up Yes
Super Resolution+ Yes
HDR (High Dynamic Range) HDR 10
SOUND
Speaker Yes 5W x 2
Audio Tuning MAXXAudio®
DIMENSIONS/WEIGHT
With Stand (WxHxD) 27.5" x 16.2" x 8.2"
Without Stand (WxHxD) 27.5" x 12.5" x 3.0"
Shipping Dimensions (WxHxD) 32.4" x 16.3" x 6.3"
With Stand Weight 11.5 lbs
Without Stand Weight 10.4 lbs
Shipping Weight 16.5 lbs
STAND
Base Detchable Yes
Tilt(Angle) -5~15 Degree
CABINET / ACCESSORIES
VESA size (mm) 100 x 100 (VESA compatible)
Power Cord Yes
HDMI Yes (White)
S/W Install CD Yes
Easy Setup Guide Yes
Manual Yes
STANDARD
UL(cUL) Yes
TUV-Type Yes
FCC-B, CE Yes
CCC (for China) Yes
EPA 7.0 Yes
ErP Yes
Windows 10 Yes
LIMITED WARRANTY / UPC
Limited Warranty 1 Year Parts and Labor
UPC 719192617421
Country of Origin China
9" LG
