SOLVED Top of screen is zoomed
I opened my bank screen to do some work this morning, strangely the top of the screen (50mm) showed what the usual screen below is (250mm) The 20% at the top is exactly like what's below only smaller. I can't get the 20% to disappear. I shut down to give it a rest but the problem remains. Some other programmes do the same thing.
Hi Ian, I found where to change it, from off to on in settings. Thanks for the info, I wouldn't have known that
