How can OST to PST conversion be performed using a simple method in 2025?
We recommend the GoldyTools OST to PST Converter—an advanced, feature-rich solution designed for reliable and efficient OST file conversion.
This powerful software comes equipped with highly advanced features that make it stand out:
  • ✅ Converts multiple OST files to PST in a single operation
  • ✅ Supports all types of OST files—including corrupted, orphaned, inaccessible, damaged, and healthy
  • ✅ Preserves original folder hierarchy during conversion
  • ✅ Exports OST data to EML, MSG, RTF, HTML, MBOX, and MHTML formats
  • ✅ Offers the ability to convert Outlook contacts to CSV and VCF formats
  • ✅ Supports exporting Outlook calendars to ICS format
  • ✅ Allows direct import of OST mailbox data into Office 365 and Live Exchange (Business License available from just $21)
  • ✅ Provides a detailed mailbox preview before initiating the conversion
  • ✅ Fully compatible with all versions of Windows OS and Microsoft Outlook
Whether you're a home user or an IT professional, GoldyTools OST to PST Converter makes the conversion process fast, secure, and hassle-free.
Users can easily and efficiently performed OST to PST Conversion process using EmailsGuru OST to PST Converter. It is designed to convert OST file to PST format with or without Outlook installation of Outlook in your computer. This tool preserves all your email and original folder structure throughout the conversion process. Moreover, it is very useful, when you can have corrupted OST file and does not have access to the data. It is fully compatible with Win 11, 10, 8.1, 8, 7, XP, Vista and all below version. It is fully safe and easy way to convert OST file to PST format, providing users a free trial version without investing.
OST to PST conversion can be performed easily and simply by using a third party tool like the Stellar Converter for OST. Though there is a manual method to do so, it does not work properly when your OST file is inaccessible and is disconnected from the exchange server. Just download the software from official site and follow the below steps and your OST file will be converted to PST file:
1. Open the software you can see that a dialog box comes at first which has 2 options: “List Profile” and “Choose Manually”. The “List Profile” automatically detects your configured OST file and selects it and the “Choose Manually” lets you choose the OST file you want to convert to PST file. Select the “Choose Manually” option.
2. Once you have selected your OST file then click on “Convert”. The software now actually starts scanning your OST file to convert it to PST file.
3. Once your OST file is scanned then you can preview to see all the data that was present in the OST file is intact.
4. Then click on “Save Converted file” under the “Home” menu. Here you can see the multiple formats in which OST file can be exported. These formats include PST, EML, RTF, PDF, MSG, HTML and MBOX (for Technician Version). Click on the “PST” format to export your OST file to PST
By these ways you can easily convert your OST file to PST in a simple process.
