- Aug 6, 2024
Hello everyone
I hope you are well. I am reaching out to the community in the interest of fixing some constant performance difficulties with my Windows 10 system. I have been suffering with these issues for a long, and after trying several troubleshooting techniques; I have not been able to identify the source of the problem. I would appreciate any advice or suggestions you may have.
System Details:
Operating System: Windows 10 Professional; Version 22H2.
Processor: Intel Core i7 9700k
RAM: 16 GB DDR4 graphics. Card: NVIDIA Ge Force GTX 1660
Storage: 1 TB SSD.
The biggest issues I am experiencing are poor system performance and occasional freezes. The performance concerns are more apparent when I use many applications and execute actions that need a lot of system resources.
Also I explored some topics related to this https://www.windows10forums.com/threads/hello-i-recently-upgraded-to-windows-10-and-ive-salesforceadmin-noticed-that-my-start-menu-is-not-functioning-properly.27184/ but I did not get the sufficient solution of my query so I would really want to get some help from a more experienced person
Thank you in advance for your efforts and help.
I look forward to any suggestions or insights you can provide
System Details:
Storage: 1 TB SSD.
- My PC takes substantially longer to start up and shut down than when I originally installed Windows 10. It frequently appears to hang throughout the shutdown process.
- Applications, typically those that use a lot of resources, take a long time to launch and may become unresponsive for short periods of time. This applies to both third-party programs and Windows native apps.
- I frequently see large disk usage increases in Task Manager, even when no heavy apps are active. This can contribute to system slowness and lagging reaction times.
- my machine completely freezes for a few seconds, making all input unresponsive. This happens unexpectedly and can be extremely unpleasant.
- I ran the built-in Windows diagnostics to check for any hardware problems. No significant issues were found.
- I took steps to make sure that all of my drivers, including graphics card and chip set drivers; were up to date.
- To filter out malware; I ran a comprehensive system scan using Windows Defender and other third-party antivirus applications.
- To optimise boot times, I evaluated and disabled any unneeded launch programs.
- To clean out temporary files and system cache, I used the built in Disk Cleanup utility.
- I ensured that my PC was up to date with the most recent Windows updates and patches.
