- Nov 18, 2024
You can simply import OST to iCloud manually or with the help of a professional tool. For manual conversion, first, convert an OST file into PST format using Outlook or any third-party tool. Later, the PST is imported into the iCloud mail through Outlook with the iCloud add-on activated. But some drawbacks come with the manual methods; therefore, all of them advise avoiding the procedures and using any professional tool.
MigrateEmails OST to PST converter is a full-fledged tool from importing OST files into clients and formats such as iCloud; tested by industry technical experts. Different features and choices for operations are provided by a simple-to-use GUI. You can import all types of email data into Outlook (all versions). Landscape and Free demo version-that is one of the best OST file import tools into Outlook so far! Let us see how one can import Outlook OST to iCloud (Apple Mail) in a stepwise manner.
Walkthrough for Importing an OST File to iCloud (Apple Mac mail) Account
1. Download and install MigrateEmails OST to PST Converter.
2. Click Select Files or Select Folder to select the OST files and then click Next.
3. Now, preview and select the files listed in the tree structure, and then click Next.
4. Select the email clients from the Saves/Backup/Migrate As option.
5. From the drop-down menu, select the iCloud option.
6. Enter your username and the app password and click on the Sign-in button.
7. After this, choose the options you want and then click the Convert button for starting the process.
