Remote Desktop Connection Using 3D Connexion Mouse
Hi I am currently working at home due to the ongoing situation.
At my place of work I usually use a 3d mouse made my 3dconnexion for my navigation around CAD models.
However now that I am using a remote connection into work I am unable to use this. My productivity is almost halved due to this reason.
Is there any suggestions on how I can use this?
Hi est1984,
I assume you are on a different computer at home, did you install drivers for the 3D mouse?. ;)
For this you can use Flexihub software. Since the mouse is usb connected, there will be no problems with sharing the device.
I am sure your 3D mouse will work.
Good luck.
