Yes, you can export OST files to PST format along with all associated data. There are two primary methods to convert an .ost file to a .pst file: manual conversion and using a professional third-party tool.
Follow these steps to perform the conversion using Microsoft Outlook:
Note: This manual method can be quite lengthy and requires a good level of technical expertise. It also depends on having access to the original Outlook profile and Exchange Server, which isn’t always possible—especially with orphaned or corrupted OST files.
If you’re looking for a faster and more user-friendly solution, try the GoldyTools OST to PST Converter. It automates the entire process, supports batch conversions, and allows you to export OST files not only to PST but also to formats like EML, PDF, MSG, HTML, and more.
Bonus: A free demo version is available, letting you preview the first 20 items from each mailbox folder before purchasing.
How to Convert OST to PST Manually
- Open MS Outlook with access to both your Exchange account and the offline mailbox.
- Go to File > Import > Import Messages and import the OST file.
- Next, go to File > Export > Export Messages.
- In the new window, select Microsoft Exchange and click Next.
- A pop-up will appear saying:
"This will export messages from the offline mailbox to Microsoft Outlook or Microsoft Exchange."
Click OK to confirm. - Choose to export either selected folders or all folders.
- Click OK to start the export process.
- Once the process completes, a confirmation dialog box will appear. Click Done.
A Simpler Alternative: GoldyTools OST to PST Converter
