Hey swantabletennis, could you provide more details? What device are you using and what exactly do you mean by the "Internet box" missing from settings? A screenshot would help too.
Are you referring to the network settings? Sometimes the settings layout can change after an update. Try checking under a different tab or section within the settings. Also, did you recently update your device or the OS?
