eaphost error 2002 Eap method DLL path typeId=254、authorId=311、vendorId=14122、vendorType=1
I want to connect to vpn but I can't connect at all. I tried many methods and still can't solve it. Through the event finder, I found two errors after each connection failure.
CoId={143AB12F-9786-491F-B562-0DCF2C9AFA86}: The user MYDVEN497MXPOM2\Administrator has made a dial-up connection named greenvpn and the connection has failed. The error code returned after a failure is 0.
But the vpn plugin I used in chrome can still continue to use
If you can solve my problem, I will be very grateful.
I have been troubled for many hours.
and sorry for using google translate because of my poor English
Hi Gailun,
it might help if you tell us what the VPN's name is?, that way we can check it out. :)
Back
