SOLVED Opening PST Files Without Using Outlook.
Unsure how to access your PST without Outlook? Files with the PST extension carry your emails, contacts and calendars, though they are usually opened with Outlook. Fortunately, the BLR PST Converter Tool makes it simple to work with big or broken PST files, even when Outlook isn’t used. Importing PST files into Gmail can also be done through GSuite Conversion for Microsoft Outlook (GSMMO) or Mozilla Thunderbird when used with the Import Export Tools NG add-on. Although you can see your images instantly online, refrain from uploading personal information to keep it safe. The methods, with the BLR PST Converter standing out, allow you to open your PST files without having to install Outlook.
