SOLVED Can not adjust sound level
Hello, I have Win 10 on for several months with almost no problems. Yesterday I had something (?) on the screen and looked away to the TV. When I looked at the screen it was rotated 90 degrees clockwise. My wife did fix that for me. but still have 2 problems. The (Window) on the far left of the task bar will only respond to a right click. Not a big deal but the speaker button on the right side of the task bar does not open the volume slider. Must left click on the speaker and go from there. A bit annoying
to me. Are all of these related ? or ???? Help.................JY
Welcome to the forum.
No idea, but....
Try running Windows Update manually.
Right click the Start Button and choose run and in the run dialog box type
ms-settings:windowsupdate
hit enter or click OK
Click the Check for updates button.
See if there is a reboot pending or any updates pending.
Ran Win update manually and no help. No reboot or updates pending. Thanks but no help Jay
