Lenovo S540 "double boots?" shutsdown when turning it on then on again by itself
Hello,
I've recently purchased a lenovo laptop model S540 Ideapad, and it has that weird thing when I turn it on the keyboard light up and lenovo logo shows up and then it shutdowns then turns on again by itself. but the second time it boots normally as it should
Is there any way to fix that?
thanks in advance
Method you use to Turnon, and to turnoff, since if shutdown is not proper it (will try to fix) on the next reboot.
