login problem
Hai Sir/Madam
I installed Windows 10 in my laptop. I secured my Lap by providing login password. It is very user friendly. I worked up to five days Nicely. but after that login password area is disable. My keyboard is working properly. But I can't Abel to login in to my computer.please help me to sort out from this problem.
Just a suggestion :
How to go to Safe Mode if you cannot login.....
Restart >
at login screen, bottom right, click the Power icon >
press Shift key and hold > click Restart >
select Troubleshoot >
select Advanced Options >
select Startup Settings >
select Safe Mode >
select Safe Mode option #4.
You don't have to do anything in Safe Mode. Just give the machine about 5 minutes, then restart your computer.
Will you be able to enter your password at login screen this time ?
Just a suggestion :
Restart >
select Safe Mode >
