Weird Display Output problems - Lenovo P700
WSH
Hi, I'm having some issues trying to output to a high res display (2560 x 1440, I have two of the same display ), unsure if this is due to having an older outdated graphics card, or if something is configured wrong.
Issue I am having is that when the displays are plugged directly into the graphics card display port the computer wont output anything to the display on boot.
However if I boot the computer up with the same display connected through a display port to 1080p HDMI converter everything works fine ( at 1080p ). If I then plug in the second display directly to the graphics cards second port then It will all run as it should, at its native 2560 X 1440. Whats more is I can disconnect the HDMI adapter and plug the display port cable of the first display into the first display and have both running 2560 x 1440.
But if I restart the computer it will still not output to these monitors, even if one is through the converter and the other is plugged in directly.
Graphics card is a - Nvdia K4200, Ive tried updating the drivers and BIOS, however the problem persists.
Any ideas what could be my problem ?
Thanks in advance for any help !
