.exe run problem
hello everyone, I have installed a new win 10. now .exe file are opening by a program named "autoplay application" they don't run by win installer default app.
I checked registry it's ok. is there any info?
Hi iashkan,
do you allow apps from anywhere in settings?:
What version of Win 10 are you using?:
https://www.windows10forums.com/threads/how-to-upgrade-windows-10-to-the-latest-version.13015/ :)
Normally this can be fixed with "select open with" then chose your Browser.
I think not!
I would go for - Settings - Apps - Default Apps.
scroll down to
The OP states that he has checked the registry, but maybe he should have another look:
Go to HKEY_CLASSES_ROOT.exe.
In the right pane, double click (Default) key and set Data value to exefile.
