after spending many hours on issues (reinstallation, troubleshooting, cleaning, safe mode et cetera) with both video and sound drivers which caused both AMD Catalyst and Windows sounds to fail, I recently discovered a striking similarity: AvmSnd.dll .
Following the reports of Event Viewer in both cases this file seems to be causing the troubles.
for AMD Catalyst crash; "AMD Catalyst Control Center Host Application has stopped working"
Event Viewer logs:
Event Viewer logs:
Faulting application path: C:\Windows\system32\rundll32.exe
Faulting module path: C:\Windows\system32\AvmSnd.dll
So, it appears that in both cases the file AvmSnd.dll is 'faulting', but I am not an expert an therefore not sure what it means: corrupted, wrong version (if so, how come?)?
The installed version of AvmSnd.dll has date 6-Dec-2011, size 100kb, description AVM TSP Sound Driver DLL, version 2.4.0.0 .
Is it safe to copy this file from another Windows 10 installation or can an update somewhere be downloaded or is there any other means for repair?
I would appreciate any suggestion in solving this problem!
Kind regards,
René Meijn
The Netherlands
Event Viewer logs:
Faulting application path: C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CCC.exe
Faulting module path: C:\Windows\SYSTEM32\AvmSnd.dll
for playing (system) Sounds from Windows: "Windows Shell Common Dll has stopped working"Faulting module path: C:\Windows\SYSTEM32\AvmSnd.dll
Event Viewer logs:
Kind regards,
René Meijn
The Netherlands
