SOLVED Link or send by e-mail AGAIN does not work
So disappointed with Windows 10. Once again, it was the same with Windows 7, I cannot send a link of page by e-mail from Explorer.
Also what is the use of this Bing thing?
What email program are you using.
If you are using web-base email program, my method won't work.
I use Windows Live Mail, and here is how to enable Page by email and Link by email.....
Go to Control Panel > select Default Programs > select Set program access & computer defaults > click Custom > under Choose a default e-mail program, put a dot at Windows Live Mail > OK > exit the window.
Open IE11 > click File > click Send > Page by email and Link by email should be activated now.
I'm having the same problem. I tried this, but in the Control Panel when I open choose, I only have a box that says use my current program. No other options are shown.
