Tiny text and toolbar are impossible to read
Fast Stone Image Viewer is good example.
Text on left are my files it relates to file explorer. They are tiny.
Toolbar with icons runs along the top. Icons are tiny
The pictures can be sized to any size as usual
Need help to get them to a reasonable size
Hello NOPD and welcome to the forum.
Is this a general / global problem or is it specific to one or two particular applications?
Have you tried experimenting with your display resolution?
Start button -> Settings -> Display
You can adjust the "size of text, apps, and other items:" there or
Select the "Advanced display settings" link at the bottom and use the drop down arrown in the "Resolution" box and maybe select something a little lower down on the scale.
I have tried everything you have suggested with no success. Not sure where to look next. Could you look at Fast Stone Image Viewer and see if it has any quirks. I used it all the time on my Win 8.1 computer. That one crashed and I'm trying to put the convenient stuff on the new one
