Wont power up and if powers up says no operating system
hi My laptop (as listed in system specs) will not power up and if it does it says no operating system. Please help!
Just browsing the User Guide, it looks like that's a pretty old system that came with Windows XP from the looks of things.
Is that 160 gig Hitachi hard drive (HTS541616J9SA00) original equipment?
IF you can get it to POST so you can go into the BIOS, is there any utilities embedded there that might allow you to test the system, specifically the hard disk?
It was working when you installed Windows 10. Has it worked at all since then? or is this the first boot after install.
