- Aug 1, 2015
As the title says, after upgrading Windows 7 (Home Premium) x64 to Windows 10 Home x64, I've noticed that there are warnings in the Event viewer every time the system boots regarding Windows Media Center. See below:
This is my third computer that I've upgraded. The other two systems were Windows 8.1 systems, so they didn't have WMC, so I haven't run into this. As I understood it, when Windows 7 was upgraded, the Windows 10 installer was supposed to remove WMC. One would have thought that it would remove all references to it as well.
I took a look in the Task Scheduler and couldn't find anything associated with WMC. I ran CCleaner on the registry thinking that maybe something in the registry was attempting to start WMC. This didn't help either.
The upgrade itself went pretty easy, but this system seems to have quirks that the first two don't have, this being just one of them. I won't list the other problems since I don't believe they have anything to do with this problem.
Has anyone else seen this? Anyone have a solution? I'd just as soon not have to do a clean install if I can avoid it.
