Check box issue
Hello all!
Today I accidental clicked on the check boxes option. After I disabled it, the rectangle around the file still remains, even when the check boxes are disabled. Also after that some weird thick borders started to appear on the buttons. This issue isn't related to the Narrator however. Can you please help to get rid of it? I tried to fiddle around it in the safe mode, tried to re-install Windows (without removing the apps and settings), and nothing help. Would really appreciated your help. Everything can be seen in the attached files.
Thank you in advance.
You have your icons set to a larger resolution/size than the desktop can handle. Try reducing the icon size
Ok, what GPU do you have and have you the latest drivers?. Have you made any changes to the system theme at all?. :)
Where exactly is this change you made to be found?. :)
I am sticking to it being a mismatch with your resolution and icon size. The squares are showing the size requested, with your resolution.
Right click the desktop and select Display Settings.
In "cale and layout" make sure you have the "recommended " setting _ Mine is 125%
I have Geforcw GTX 1660Ti Mobile, the drivers are up to date, and the place where I made the changes is here (it is unchecked now though):
I already checked that. It is at 100% which is the recommended setting.
Sorry. I would have thought someone would have popped into this thread with a useful idea, but it looks like it is dead in the water.
Do you have switchable graphics?, I assume you have a laptop and you can try switching off the Nvidia GPU in BIOS/UEFI and use the integrated GPU (I assume Intel). That might solve your problem?. :)
Yep, I have a laptop with switchable graphics. But when I switch off the Nvidia GPU, that will probably mean it won't be working anymore for example with games. Or I am wrong?
No you are right, I ask because you should just try and switch GPU's and see if it solves the problem!. :)
