CORTANA PROBLEM
Windows 10 was updated through the proper channel and CORTANA has been working fine. I rand a Privacy program and all of a sudden Cortana is gone and I get a meddage that my company has prohibited use thereof. I am a sole user. How can I reverse this problem?
Hello Dorian, maybe give System Restore a try?
Right click the start button and choose system
From the left column choose System Protection.
Click the System Restore button
Click the Next button
You may need to check the box at the bottom that says, "Show more restore points"
Pick a date / point in time before the problem occurred and see if that helps.
You're welcome.
Glad to hear that you managed to resolve your problem.
Thanks for the follow-up and lettings us know that you solved the problem.
Regards
Randy
