Does it matter if i have a 32bit OS on a 64bit system?
H, I have a PIPO W3F .
It's like a Chinese Surface clone that runs both Windows and Android.
It isn't very well supported & I only saw one place to download a Windows 10 upgrade.
I recently updated the Windows 8 system to Windows 10 32bit.
It seems to be working fine, except that its a 32bit windows 10 running on 64bit architecture.
Is that ok?
Thanks
Yes it is OK. For many years people have been running Windows 32bit on 64bit hardware. It was a waiting game waiting for Windows 64bit to mature enough for migration away from 32bit.
Umm - the major difference is that a 32 bit O/S will only ever support 4Gb of memory (actually, a bit less). So, if you have more memory, its just wasted space.
As to waiting for Windows 64 bit to mature - it's already fine and running in most commercial organisations. So, what are you waiting for?
Since the device you are talking about is particularly unique, in that it dual boots two completely different Operating Systems, I would be extremely cautious about going to a 64 bit version of Windows.
There is no direct upgrade path from a 32 bit OS to a 64 bit OS and consequently would require a clean install of Windows, and could conceivably hose your boot loader.
I would double check with the manufacturer as to whether or not, such a thing, is even supported on that device.
32 bit Windows may be a requirement to support the multiboot feature.
