hard drive failed and the efi partition was deleted
the hard drive in my pc failed yesterday i managed to get almost everything back but the efi partition is lost so i can't boot into windows 10 is there anyway i can recreate it??
i use a gpt motherboard
If you have experience with Diskpart, you can use the cre par efi to get it back. If you decide to do that, check back before you change anything.
Once you get it back and formatted,you would need to use bootrec /rebuildbcd or the bcdboot C:\Windows command to restore the BCD store so the system will boot.
