Issue with system UI
Hello I am attaching a photo. My PC will show an empty box for a UI such as system or control panel and even my system tray can anoyone give some advice? Even chrome has this issue is a cache issue a possibility?
Hi Dominique,
It's possible some system files may be damaged.
If you able to try the following:
  • right-click on Start and select Command Prompt (Admin)
  • When the User Account Control opens click Yes
  • In the Administrator: Command Prompt window that opens type the following:
    Code:
    SFC /SCANNOW
    Press Enter key to execute.
    When done, close window and restart computer to see whether the issue is resolved.
Report back if the issue continues.
Ahh, sorry I did not enlarge the attached photo but now see you tried that all ready - sorry.
Have you burned the windows 10 iso image to a DVD or created a boot usb stick?
If you have I can give you some instructions on how to use that to attempt a repair.
