Your settings for MMS (Multimedia Messages) may be turned off.
On you device go to Settings | Messages | then scroll down and under SMS/MMS
make sure you MMS option is turned on
Another issue may be how your device is connected to the internet; Cellular or WiFi. Some Cellular networks using APN will not allow images being sent or received by default. However you may be able to edit this.
Apple provides a support article that explains the above:
If you are not using an iPhone but rather a Windows 10 Phone (Lumia for example) then read this Microsoft Article instead that explains the same thing:
