I believe that it associated with certain AMD video cards and associated CCC (Catalyst Control Center) software.
You can try the simplest and most often recommended solution, which is.....
Right click the Start Button, choose Device Manager from the context menu
Expand Display Adapters, right click yours and choose uninstall. Then reboot the machine.
If that seems to work, then you're done, at least temporarily
IF not then you may need to do some further troubleshooting http://support.amd.com/en-us/kb-articles/Pages/26494-Radeon-MOM-CCC-implementation.aspx
