Monitor stuck on power saving mode , but hardware still running ,when use sleep or hibernate
When modes sleep or hibernate are used , hardware remains active and video monitor enters and get stuck on power saving mode.
As sleep mode was causing the issue frequently I decided to enable the hibernate button but even with hibernate occasionally the issue occurs.
Seeking for on Google I´ve not been able to find a solution .
Needing some help. Thank you.
Hibernation is mostly used by battery-operated computers, not by mains-powered ones.
Have you tried using the computer without the "Sleep" option activated? If so, does the monitor freeze at all?
Resetting the graphics driver with Win+Ctrl+Shift+B causes the screen to briefly go black if the monitor is still frozen.
No , because I need the "sleep" function. I use it to sleep the system when I go out for lunch or for any other reason every time I will go back soon. This avoids the pain that is to boot the system. I´ve just employed hibernate function as a workaroud.
When sleep fails as described Win+Ctrl+Shift+B does not restore the videoo.
if its plugged in, why tell it to sleep...make the monitor sleep and NOT the laptop/Desktop.
yes it is plugged in but "sleep" keeps the power consumption to a minimum , the energy here I live is very costly.
