Problem locking my folders in Explore
tried a test after reading how to lock a folder here:
https://windwos10explore.blogspot.c...howComment=1494025050189#c9142412565788589862
and worked like a charm. Then i moved the folder to another place and it still worked. But when I tried to do it again on another folder i cannot RT CLICK the folder to get the TEXT DOC OPTION TO SHOW UP!! IT ONLY SHOWS FOLDER when i RT CLICK!! WHERE ARE THE REST OF THE OTHER OPTIONS?! I THOUGHT IF I REBOOT IT WILL SHOW UP!? STILL NOTHING!! help someone?? THanks!!
PLEASE ANY SUGGESTIONS??? STILL CANNOT GET THE OPTION FOR TEXT DOC!! THANKS!!!
Hi Deb4Health,
  • In your search/Cortana field type comm
  • In search results select Command Prompt
  • In the Command Prompt console type or copy & paste the following:
Code:
REG QUERY "HKEY_CLASSES_ROOT\.txt\ShellNew"
Press Enter key
Do you see the following results. Yes/No?
