Storage problems?
I recently updated to windows 10, and I though all was well.
But I have now noticed I have 558 GB of hard drive been used under the Apps and Games section?
I have used the new storage page, and there is nothing much really in there?
I am really at a lose for what is taking the space up
Can anybody help
If you are referring to the Settings - System - Storage, mine shows the amount of space used on the C: drive. So yours is using 558 GB out of How Much?
My hard drive is 1T, its just a bizarre amount
This not my PC but where it is highlighted mine says 558GB
There may be some info which would help you get a better answer. Of the 558 GB, how much do you think is bizarre? have you checked the folder individually to see is any show some large amount.
If you upgraded to 10, you may have a Windows.old folder which is an archive of your old files. You may have an image which was used to upgrade the system.
Try to find where the overage is located and track it down. Right clicking a folder and selecting properties will show how much is in that particular folder.
Some folks might recommend a utility named TreeSize to show detailed info about your data. I have no experience myself.
Sorry, I am not familiar with your attachment. Is this a Windows 10 utility and if so what is the path to get there.
Otherwise, my previous post is all I can think of.
Cloud storage 11
Picture storage... 3
Low storage on Lenovo 2
SOLVED What file system should I use for Storage Space (Two-way mirror) ? 2
Cloud storage for large files 4
SOLVED New Feature Storage Space 3
Storage issues 7
Increase SSD or storage? 17
