SOLVED Strange characters when typing (ctrl shift does not work)
I have a very strange problem. When I type for example 'p' it gives 'op' or when I type 'o' it gives 'kop', most characters on my keyboard give such strange output, a few are ok. Ctrl shift is not the solution.
Somebody a brilliant idea??
What languages are installed? What type computer, Desktop or Notebook/Laptop? Have you tried a different keyboard on the Desktop or added a USB keyboard on the Notebook? Have you used a canned air to blow out any dust/hair/crumbs? Have you shut down and removed any power sources for a minute or two and tried again?
Thanks for you help. I put out the usb plug of the wireless keyboard, and put it in again. And now it's working properly. Great!!!
