- May 6, 2025
There are numerous situations where converting an OST file to PST becomes necessary. Common scenarios include:
Unfortunately, Microsoft Outlook does not support directly opening OST files across different profiles or systems. To resolve this, a reliable third-party solution is required.
I recommend using GoldyTools OST to PST Converter, one of the best tools available for safely and efficiently converting OST files.
The free demo version allows you to preview the first 25 items from each mailbox folder, giving you a clear look at the data before committing to the full version.
- OST file becomes inaccessible due to an unexpected power outage
- Exchange Server crashes or becomes unavailable
- The OST file is orphaned following changes to the Outlook profile
- A user needs to access an OST file from another Outlook profile or device
Key Features:
- Fast and accurate conversion of OST to PST
- Support for additional formats, including EML and MSG
- Compatible with all versions of Microsoft Outlook (both 32-bit and 64-bit)
- Full support for all Windows operating systems
