SOLVED YouTube sizing problem?
I was scrolling through the right hand thumbnails on YouTube last night using the mouse wheel when instead of going up and down the wheel made the images go bigger and smaller, then it went back to normal but the images were stuck on a large size? I restarted my desktop computer but it remained the same? Nothing else has changed just YouTube. Ive checked YT settings but couldnt find anything to fix it, Any ideas anyone?
Were you accidentally holding down the Alt key while scrolling?
No, I dont think so? Would I be able to resize it by holding the Alt key down? Solved! There was a piece of biscuit in the CtrL Key that caused it and pressing that key and scolling resized the screen.
Thankyou very much, If you hadnt have told me that I wouldnt have fixed it so quick.
