Zoom settings
When using edge my age and eyesight means I have the zoom setting at 125%. Trouble is, whenever I change pages, the zoom reverts back to 100%. Is there a setting that will lock the zoom at 125% for all time....?
Any and all help greatly appreciated.
Rob
Use the Ctrl key and the "+" or "-" keyboard shortcuts to manually change the settings. This will increase or decrease the page magnification. If you're using a mouse, you can zoom in or out while holding down the Ctrl key on your keyboard.
I have used the display setting so that all apps are zoomed to 125%. In the start menu click "Settings", "System", and "Display". Then scroll down until you see "Scale and Layout". Just below that is the selection box that you can use to select 125%.
You can use "Windows and + (plus icon)" to open a magnifier that will zoom any program for you.
you can use this article for more info on windows magnifier
