SOLVED Do away with logging in at start up
In the Windows 10 user accounts I’m the only one listed as I’m the only user. I get asked for my Microsoft Account password every time I log in which I don’t want. When I press the Windows key and R to open the run box and enter netplwiz it opens the user accounts box and I’m the only one there but it does not have the box saying, ‘Users must enter a user name and password to use this computer.’ How do I get rid of having to enter a password when I can’t untick that box?
which version do you have?? Home or Pro??
In the home version one cannot untick the box as far as I know, only on pro and enterprise versions.
the easiest wat may be to remove the password altogether in [settings]->[account]->[sign-in options]. if that does not work either, it may not be possible to do without a hack in the registry and that is not a given either.
I'm using home. Not just a matter of not being able to tick it as it isn't there at all!
Settings, accounts, sign in options is a no go as well. Just the usual stuff about Windows Hello options none of which interest me.
Just wondering what would happen if I switched to a local account instead?
that might be a better option. Me personally always have local accounts, not associated with any email whatsoever.
give it a try. you can always undo that one.
This is one of many reasons I never do Home versions as they are to restrictive and not the user is controlling it but Microsoft.
Are you saying that a local account would screw up my email as I need that functioning properly?
Have to look at this again tomorrow as I'm going square eyed!
That is the only way. When you use MS account to login, it will require a password. Because you are essentially logging in to MS online when you do.
That is not what I said. My local accounts are not associated with any email account. your email functions are continuing to work even with a local account. Your local account can have a password or you just leave it blank and it will then not stop for a login-prompt.
I am using this method on my insider system without any problems.
Okay I switched to a local account and it seems to be working okay. Only started playing up after the last update as there was never a problem in all the years I've had the computer. It always logged straight into my account when I switched it on. I guess that's why I have updates disabled most of the time until I'm sure they are not going to cause problems which unfortunately is always the case with Windows!
