Fingerprint scanner question
ok i had an issue with the fingerprint scanner and then discovered my machine did not have one. it has blank core in that spot. i got another machine the same model and that had the scanner and the camera. and i got it to work for the sign in from turning off or switching users.
now can anyone tell me if i can use this scanner to actually log into web sites like my banks. if i can is there a video showing how or instructions? it would be more secure to use my fingerprint for logging into banks than the password don't you think? hard to keylog a fingerprint or are they just as bad and can they hackers get past them also? thanks bp.
the software is use came with the laptop and windows 10 or a before win 10 operating system. it now works good to lon into the machine but curious if i could count on it for a secure log in to the banking sites. i have read now that the bios scanner has been hacked. you would figure someone found a way to hack it. if so then i will just keep using the keyboard. thanks
